Rotate Excel Data
PMCap
Does anyone know the process for rotating data on an EXCEL data sheet. I do not want to transpose the data. I want to just physically rotate the data.
Example left to right columns are labeled A B C D Rows within the columns are labeled 1, 2, 3, 4 as follows
A B C
1 3 4 5
2 6 8 2
3 2 9 1
I would like to rate 90 degrees clockwise to the following:
3 2 1
A 2 6 3
B 9 8 4
C 1 2 5
Thank you
You could possibly do a reverse order sort on the rows, then transpose.
TTFN
faq731-376
7ofakss
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
Here's a UDF that will do it:
Code:
Function RotateRange(RRange As Variant) As Variant
Dim NumRows As Long, NumCols As Long, i As Long, j As Long, RotnA() As Variant
RRange = RRange.Value2
NumRows = UBound(RRange)
NumCols = UBound(RRange, 2)
ReDim RotnA(1 To NumCols, 1 To NumRows)
For i = 1 To NumRows
For j = 1 To NumCols
RotnA(j, i) = RRange(NumRows + 1 - i, j)
Next j
Next i
RotateRange = RotnA
End Function
Enter as an array function and it will return a rotated version of RRange.
Please ask if anything isn't clear.
Doug Jenkins
Interactive Design Services
