What type of rotary airlock are you using? Some are designed better than others. A round hopper bottom tends to direct the flow to the center of an airlock. If the flow is high and the material piles up in the center so that the rotary vanes have to shear off the pile every time the pocket closes, there will be high wear in the center both on the wall and the blades.
Some models of airlocks have "shoes" that are pulled against the rotor with spring action. The intent is well intentioned; to maintain a tight seal. However, I have never seen those work well; the springs always end up with unequal force and the shoe gets "cocked" causing unequal wear, IMHO.
I prefer a square hopper botton into a square rotary valve. That way the flow from the hopper is spread as evenly as possible throught out the rotary valve, not just toward the center.
Rotary valves are going to wear. That is a fact of life. However, you get to pick the wear point. I always specified and operated rotary airlocks with hard chrome plated bores and soft (sacrificial) steel vanes or vane tips. When I could, I used soft steal replacable wear strips. In theory the wear strips can be reversed, using the good edge when the other edge becomes worn, but in real life, it is just as cost effective to replace the wear strips when the valve is out. Wear strips are cheap, labor to change them is expensive where I came from. Set the gaps with feeler gages and the valves will get remarkable life.
I used rotary valves where the material being collected contained combustables so any back leakage into the airlocks could cause hopper fires, so maintaining tight airlocks was critical. I found Wm. W. Meyer in Skokie, IL a good company to work with. They knew their stuff and wouldn't mislead you. I hope something here helps.
rmw
