We are having issues with pressure/flow of the lube oil system on a roots type (screw)blower. The lube oil is being pumped by an IMO (connected to the shaft) with in the blower housing. The oil is also sitting with in the blower casing and the pump basically pumps the oil to the bearings and then filters it through and cools it down through and exchanger (typical of a lube skid). However, operations has been saying they have observed occasional loss of pressure/flow through the lube oil skid system.
I have only recently taken this problem on hand trying to possibly move into a root cause study. But nothing is popping out of the ordinary at the initial investigation. The only thing I am thinking about is the fact that there is a little screw on the IMO pump itself which is adjusted to control the pressure/flow through the pump and this might be loose or something. But again operation says this happens occassionaly and I'd assume if it is a screw issue on the pump then it should not happen intermittently but should rather continious.
I would like to hear your thoughts, if anyone has had much experience with such lube oil skids on these blowers and potential points of issue.
Thanks and much appreciated.
