I have a question regarding how to size the roof drain discharge sewer to nearby manhole.
For building, when we size the roof drain, the national plumbing code has form to select the roof drain size based on 25mm/15min storm for most area in Ontario.
When we size the storm sewer, water flow is from Rational Method Formula Q=CIA, I(mm/hr) rainfall intensity is from City's IDF curve. If I=190mm/hr(5-year), the water flow is bigger, we need much big pipe than using plumbing code.
So How to size the building discharge sewer, follow the plumbing code or Q=CIA?
Appreciate your help!
