Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
You fabricate steel trusses on site?
hocho said:isn't it that the members of the trusses can bend in response to wind, whereas in wide flange.. it is often stiffer than the stress are transferred to the connections? Which is better.. stress in the members of trusses or stress in the connections of stiffer wide flange rafters?
Comparing these three systems:
1) A pitched roof truss with a flat bottom chord.
2) A pitched roof with rafters supported on a central ridge beam.
3) A pitched roof with rafters not supported on a central ridge beam.
hocho said:how do you detail the connections.. by simply cutting and welding the wide flange at an angle?
hocho said:Would this even be stable?
