gatz
- Aug 4, 2003
- 68
Coupla questions...
1) When drawing up some #41 chain sprockets; using Circular Pattern (under SketchTools) for the tooth profile, how can you select using windowing? Seems it only allows picking one entity at a time to add to the items to pattern.
2) Is it possible to show simulation of roller chain about two sprockets? (ie chain links changing from circular movement to linear, and cycling)
Thnx, Gatz
Thnx, Gatz
