Roller Chain Connection
feb14
I need to use roller chain to operate a mechanism over a 41 inches center to center distance. Speed is almost negligible, but the force of operation is high. My center distance is fixed with no room for adjustment of chian tension. I will like to be able to find some adaptor for connecting the chain so that I can use the adaptor for tensioning the chain. I will prefer a bolt connection for the adjustment but I am open to any ideas now. Please help.
You can't change the length except in integer pitch increments. Otherwise the chain can't pass over the sprockets its connection point. You can get single-pitch increments by removing link pairs or by using a "half link" to connect the ends.
You might also consider the floating block type of tensioner that clamps at the middle of the loop. Take a look at page 986 in the McMaster catalog:
Don
Kansas City
Thanks Eromlignod. I have already checked the Mcmaster tensioner and its too bulky for my application. I dont have the space. My chain is not going to run continuous. I am only going to be moving back and forth over a 180° angle.
How about a turnbuckle at one end?
Don
Kansas City
Can't use an idle for tension?
Thanks a lot for your responses. The turnbuckle seems like a nice idea. I just have to find a size which will work with a size 40 chain.
Thanks again guys.
