Feb 28, 2006 #1 limct Mechanical Joined Jan 27, 2003 Messages 134 Location HK I'm looking for rolled pin of diameter 3mm and length 56.5mm, or round figure, 55mm is acceptable as well. But so far I only manage to get 40mm max length. Can anyone help? Thanks a lot. Best regards, ct
Feb 28, 2006 #2 CoryPad Materials Joined Apr 15, 2002 Messages 5,192 Location US Spirol stocks a standard part with 3 mm diameter and 50 mm length. Perhaps they will make a nonstandard part so you can get to 56.5 mm. http://www.spirol.com Regards, Cory Please see FAQ731-376 for tips on how to make the best use of Eng-Tips Fora. Upvote 0 Downvote
Feb 28, 2006 #3 diamondjim Mechanical Joined Jul 30, 2000 Messages 992 Location US I would think a 50mm length would be more than suitable. How much penetrates into each part? Upvote 0 Downvote
Feb 28, 2006 #4 unclesyd Materials Joined Aug 21, 2002 Messages 9,819 Location US Vogelsang offers a 3mm roll pin in 50mm length. Is it possible to use 2 pins? If the quantity is sufficient you might try Apex as the quantity requirements for the major pin manufacturers was quite high. Vogelsang http://www.rollpin.com/ProductInformation/Springpins/Rolled/rollpins_practical_size_metric.html http://www.apexfasteners.com/index.htm Upvote 0 Downvote
Mar 1, 2006 Thread starter #5 limct Mechanical Joined Jan 27, 2003 Messages 134 Location HK hi guys, thanks for the feedback, I've sent the inquiry to the potential suppliers. Best regards, ct Upvote 0 Downvote
