ROI Emergency Generator 4
emfrey
3
I found an ROI Generator about 30 years old with following model #
Engine: ROI "Crown Line" H884-V8
Generator: Model# HAA4CU
Size: 5-3/8x4x7/8 or 5-3/8x4x7/85
Serial# 65X2348
Spec G-27790 - 1800 RPM
Can anybody help me to find the KVA or KW rating or guide me to Manufacturer's data for this generators?
Your help will be greatly appreciated.
Thank you
may be a place to post your question about the engine and generator as well.
Is ROI short for LEROI? an old engine manufacturer in the USA. Is the engine diesel or spark ignition? Turbocharged or NA? Where are you located? So many engine manufacturers have been bought up and the names have disappeared in the last 30 or 40 years.
Agree with ccjersey--do a search at Smokstak. Unfortunately, if you search there, you'll find that Le Roi's aren't really supportable anymore.
Hello emfrey
Try this, shown in some listings as Waukesha ROIline.
Engines Classification and Rating. Manufacturer................... Waukesha Motor Company Model.............................. T-H884 Type................................ V8-w/valve in head, 4 cycle Number of cylinders ........ 8 Piston displacement ........ 884 cu. in. (cubic inch) (es) Bore ................................ 5 3/8 in. (inch) (es) Stroke ............................. 4 7/8 in. Maximum torque at ......... 780 ft-lb (foot-pound) (s) 1,800 rpm (revolutions per minute). Maximum horsepower ..... 330 rating at 2,600 rpm. Compression ratio ........... 7.6:1 Cylinder liners ................. Replacement wet-type Piston pin type ................ Full floating Valve type....................... Straight b. Engines Repair and Replacement Standards. Table I lists manufacturer's sizes, tolerances, desired clearances, and maximum allowable wear and clearance. 3
I would estimate it at 125 to 150 kw.
From the compression ratio I assume that it's a gasoline engine.
yours
Here's some spark plug information;
COMMERCIAL EQUIPMENT - INDUSTRIAL ENGINES
LE ROI
GASOLINE
H844 . . . . . . . . . . . . . . . . . . . . . . . . 295 SE458 .030
ROILINE (Cont’d)
GASOLINE (Cont’d)
H540, H844, H884 . . . . . . . . . . . . . . 303 AP303 .025
TH884, H570, TH570 . . . . . . . . . . . 303 AP303 .025
WAUKESHA
GASOLINE
14mm Heads
Generator Sets . . . . . . . . . . . . . . . . 295 SE458 .025
H540, H570, H844, H884, H884G . . 303 AP303 .025
NATURAL & LP GAS
14mm Heads
ICK, F554G, H884G . . . . . . . . . . . . 303 AP303 .016
yours
Thanks ccjersey, powerwagon75, and waross for yor help.
ROI might be short for LEROI we do not know.
The Gen-set is located in a high-rise building in Miami, used for standby emergency power.
The engine is Natural Gas powered, with spark-plugs, and turbo charged.
We posted the question at Smokestak and hope for reply.
We are also picking up on walross suggestion to look at "WAUKESHA ROI Line". Great info, thanks.
We will post our findings.
On a similar note we have a 1967 Roiline H884 (65X1527) engine driving a Kohler generator Model 140R77 (SN 300-489; Spec. 9901A). It uses natural gas and the book mentions one of two Delco Remy distributors for nat. gas applications, one of which is #1110622. How hard would it be to match the part number for the distributor points? Kohler doesn't support it. They say that the engine was originally bought from Waukesha.
By the way, assuming our unit is similar to emfrey's I'd be happy to share any info our service literature might contain that would be helpful. just let me know.
