Robots off-line programming
  • Thread starter Thread starter zimmy
  • Start date Start date
Z
zimmy
Guest
Hi
I'm going to install a robot for welding applications.
Just because ProE has not a specific module for this
type of Off-Line Programming, I ask if anyone of you has an experiece
with other applications for robots programming.
I know RobCad, there are any other SW ??
Pier
What kind of robot.. Fanuc, Motoman, ABB?
Kawasaki Robor for welding
Type Fa10L-FD40controller.
Generally speaking, I wonder if there are speialistic software for programming.
We use Fanuc & Motoman; both have offline programming software. We use Fanuc's WeldPro. If you are doing small weldments with just a few welds, offline programming is great, but if you get into larger weldments I would recommend programming at the robot. No matter which way you choose, you'll still have to touch up program points at the robot.
That being said... Delmia makes software that works with many different robots. I've never used it & its very expensive.
