robertson QL-deck
dwray
Does anyone have information on Robertson QL-21-20 floor deck. I am checking a floor which was built in the late 60's, early 70's. I know that the deck is 3" deep with 2 1/2" concrete on top of that. I need to know the span ratings and the profile of this deck. Any help would be appreciated. Thanks.
I've got catalogue cuts and ICBO information. How do you want it transmitted?
Thanks. However you can. .pdf or .doc would be fine.
Do you need my email address or can you send it to this site?
Fax would be easier, but I'll need an Email address if I have to scan them.
My fax is 704 561 8700, Att: Dan Wray
My email is dwray@littleonline.com
Thanks.
I think I need the '74 edition. I need info for QL-21-20 deck.
That was exactly what I needed. Thanks Jed.
hi,
Just to let you know if this will be of any use towards your enquiry, check modern steel construction site via and paste this up in the solutions section.
I will do the same from my end.
aileme (Structural)
