ROAD GRADES
Ayan93
1
CAN A CONSTRUCTION TRUCK STILL DRIVE IN A GRADE OF 20% WITH LENGTH OF 500m?
depends
what kind of truck
what kind of load
what kind of pavement
you will need specific data on the truck
Also is it going uphill or downhill?
does it start and stop?
Most crawler gears will do this, but it's not the only issue.
"Construction truck" is remarkably vague.
PS please don't write in capitals, it's interpreted as SHOUTING and it's not allowed.
Answer: No. Reason: Rain.
On a recent project, we had a temporary access road constructed at a 10% grade, it was capped with aggregate. Loaded semi's were unable to make it up the slope in wet conditions. It was an expensive mess to get the 2 trucks that got stuck unstuck....
20% is way to steep for material delivery-type trucks. Add water and it only gets worse.....
