Barney4671
Western NC mountains. Helena storm water runoff caused a loss of 15ft long, 10ft down, and approx 8ft wide road shoulder dirt at the location of a 8-inch road surface water discharge drain. It appears that prior to washing out the drain and discharge piping cracked and sent a water jet back towards the center of the road resulting in a 3ft "cave" under the asphalt (which has subsequently collapsed). The uphill side lane appears fine and still intact and in use. Last couple days dump trucks of boulders have been delivered for a different wash out.
Question is how far from back of the wash out "cave" should cars pass. Is there a rule of thumb as to how much dirt is needed to support the road - like a 45-degree stress cone - how close to wash out can a car drive without causing more damage?
How urgent is a fix needed - couple of months, years?
This is really outside my wheelhouse, so any help would be appreciated.
PIC attached[URL unfurl="true"]https://res.cloudinary.com/engineering-com/image/upload/v1728426083/tips/Wash_Out_l2phu0.pdf[/url]
