manv
- Oct 2, 2003
- 7
sir itis noted while checking 4 a ripple content across a wet bat using digital multimeter ripple voltage (Vac) was found 2 be higher than bat voltage reason may be explained . when the polarity is inter changed in the multi the reading is zero
