Think of a large sluiceway through a dam, lined with stainless steel, and subject to flow-through velocities of 20 m/s and carrying large quantities of sand and gravel. The steel surface after time has taken on a ripple-like surface erosion not unlike a sand dune pattern. Thought to be due to erosion by sand in high-intensity turbulence in the boundary layer, but are there any other thoughts? The ripples are typically about 10 mm crest to crest and a fraction of a millimetre deep, and the erosion is almost like the steel has been "stretched".
