ramihabchi
- May 1, 2019
- 98
When we can suppose a beam as rigid support for a slab?is there any deflection ratio for that?I have read on the internet that a thickness ratio of 3 between beam and slab guarantee rigid support behaviour.but in my case I want to know if there is a deflection ratio so I could for example check composite beams or hidden beams with high reinf ratio if they are enough stiff to be considered rigid
