Aug 9, 2017 #1 Boiler106 Structural Joined May 9, 2014 Messages 214 Location US ASCE states that rigid roof insulation weighs 1.5 psf per inch of thickness, whereas, polyiso insulation, like Thermax, is < 0.25psf per inch. Is there a reason why ASCE might be so much heavier? Is it assuming some sort of saturation?
Aug 9, 2017 #2 spieng89 Structural Joined Jun 30, 2015 Messages 172 Location US ASCE tabulated weight values are known to be conservative, if you can justify a lesser weight with documentation and you need that extra weight savings then feel free to do so Upvote 0 Downvote
Aug 9, 2017 #3 SlideRuleEra Structural Joined Jun 2, 2003 Messages 5,527 Location US ASCE is probably referring to older wood fiberboard roof insulation. http://www.SlideRuleEra.net http://www.VacuumTubeEra.net Upvote 0 Downvote
Aug 9, 2017 #4 dik Structural Joined Apr 13, 2001 Messages 26,126 Location CA or just a catch all for any rigid roof insulation. Dik Upvote 0 Downvote
Aug 9, 2017 #5 XR250 Structural Joined Jan 30, 2013 Messages 6,229 Location US Maybe once the membrane is shot, they assume it absorbs water :> Upvote 0 Downvote
Oct 23, 2017 #6 P205 Structural Joined Mar 2, 2008 Messages 136 Location CA I'm looking into this at the moment and stumbled across this thread. I have no problem using the catch-all value for normal gravity design, my issue is with the wind uplift, you would want to use a more accurate value. Upvote 0 Downvote
Oct 23, 2017 #7 IRstuff Aerospace Joined Jun 3, 2002 Messages 44,902 Location US Wood shake roofing comes in around 4 psf wet, and 1.5 psf dry. TTFN (ta ta for now) I can do absolutely anything. I'm an expert! https://www.youtube.com/watch?v=BKorP55Aqvgfaq731-376 forum1529 Entire Forum list http://www.eng-tips.com/forumlist.cfm Upvote 0 Downvote
Oct 23, 2017 #8 DETstru Structural Joined Nov 4, 2009 Messages 395 Location US The ASCE number is way off compared to what is typically used for rigid insulation. Use a value based on whatever product they're specifying. Upvote 0 Downvote
Oct 23, 2017 #9 Ron Structural Joined Sep 24, 1999 Messages 16,336 Location US The 1.5 psf/in is consistent with lightweight insulating concrete. Rigid board insulation is much lighter. Upvote 0 Downvote
