Hi, I want to use an RF Switch that has two control signals A,B and supports only two states (RFC to RF1 and RFC to RF2)according to the input voltages at A,B. What would happen if I put the same voltage at the two control lines(0 Volts at A and 0 Volts at B). I want the switch to be off! I haven't found a switch that has the unused states defined. But I need to have it off when I want to...
the switch is :
Thanks alot!
the switch is :
Thanks alot!
