Revolved Protrusions
  • Thread starter Thread starter romaxtech
  • Start date Start date
R
romaxtech
Guest
We've just started using ProToolkit and are trying to take a sketched profile and revolve it to make a solid protrusion. No luck so far. We've managed to get the same profile to extrude without any issues, but can't find any documentation on revolving. Anyone got any tips / hints / sample code they would be willing to share? Cheers!
If toolkit is like everything else, don't forget your centerline?
I think that you will find a solution to your problem if you leave pro/e leads you.
You will see that when you are making a revolved protrusion the system asks you for a centeline so can revolve the sketch around it.
Dont forget to read above everytime what the pro/e demands from you to solve the feature
I
Hi ander
You can get code for extrude protrusion by this path
C:\Program Files\proeWildfire 2.0\protoolkit\protkdoc\IESwing.html.
C:\Program Files\proeWildfire 2.0\protoolkit\protk_appls\pt_geardesign
regards
chandra
