I
intrepid86
Guest
Hi, first time here. Many thanks if you are able to help.
Using pro engineer I have created a 's' (on its side)
wrapped round a circular tube. However attempting to make
one of the 'upper side' smaller than the other has meant
it has a very Sharpe trajectory and has left a gap in
between the two of the sweep protrusions.
Using the boundary blend tool covers up the unsightly
gap. However it is only aesthetic the gap still remains
behind. Is there a way to fill in this gap quickly So I
might be able use mechanica on it?
03_094139_Gap_for_filling.JPG">
Thank you once more.
