Revolved Powercopy info
RyanRun
Automotive
Jan 12, 2006
59
I am trying to create revolved powercopies for different style ports.
I looked at the ones on CATBlog, but am unable to follow how they were created...or understand what was done.
I am creating a solid block and then creating a revolved port (Material removal). I then following the steps to create the powercopies of just the revolved feature of the catpart.
However, when I place the powercopy, instead of it going into (perpendicular) to the face I want, it goes in parallel...the port is sideways.
Has anyone created these types of powercopies and if so, do you have any step-by-step documentation?
Thank You.
Ryan
Got it!
Its a little confusing, but you need a point (Isolated), a line through the point and normal to a surface, an axis system and then a "positioned" sketch for the groove (Using the axis system, point and line).
Ryan
I often found the revolving features cause problems when instantiated, it happened to me more than once using shafts.
Yeah, the positioned sketch is a powerful feature, and if properly used can be very helpful.
Steli
