Revit Structure 4 & Etabs enabler
IngNunez
PR
Where I can download the Revit Structure 4 to Etabs enabler?. I tried to find it in the CSI web page but I cant find it.
you cant find it as revit4 and etabs dont work togather. !! and CSI sayd it wont be further upgarading as its causing them imnese problems in doing so !
but revit 3 works with ETABS !!
The enabler of Revit4 is for ETABS v9
Diquan
ETABS 9.1.5. and REVIT 2008 integration is now available.
I have just installed the upgrade 9.1.5 and the new integration module and it works great.
This is a little off topic, but I'm getting into full scale computer modeling and am pretty unfamiliar with it. Etabs is a tool for modeling the entire structure correct? And Revit is like autocad, you draw your structure, and can then import it into etabs, right? Revit doesn't actually do any analysis is what I understand? Other programs similar to etabs are ram structure and tekla, right?
