Revision Level in Title Block
chrissyd
22
I checked a drawing in to PDM for the first time. I have the revision scheme set up as: 00.0 for primary and seconday and 00 for tertiary. Once the part/drawing are released it will read A.0 00, but for right now reads 00.0 00. The tertiary is there only as a ticker for check-ins. I made minor changes to the drawing, saved and checked it back in. In the vault the revision is now 00.0 01, like it should be. When I check this drawing back out into my work space, I am asked if I want to overide the file that is already there? And I click "yes". However, the drawing opens up and in the title block the revision level still remains at 00.00 00, even though the minor changes I made are there. Is this something that needs to be fixed in the properties of my drawing format? Has anyone experienced this?
PDMW Admin needs to change the setting "Enable Revision Table" under the Revision Table tab.
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-06)
