Revision block notes management 2
CAD2015
Automotive
Please, see the brown colored HS initials.
It has been positioned linked to another note that has been deleted (a previous note under the AUTH, on the left of initials).
Is it possible to make this initial active again?
MZ7DYJ
 http://files.engineering.com/getfile.aspx?folder=5bc56088-8d1f-4fe3-8012-36f10010208c&file=REVISION_BLOCK_NOTES.pdf
NX8, please......
MZ7DYJ
The note lost its associative origin. Drag the note a small distance then move it back or use the edit origin tool to pick a new origin point.
www.nxjournaling.com
It doesn't move anymore.......
MZ7DYJ
I'd like to know if there's a way
to make this note active again......
MZ7DYJ
when you do what Cowski said uncheck Associative in the Origin Tool menu box
Great!
Thank you Cowski and Jerry!
MZ7DYJ
