I received a model from a customer as a step file. The original models were created in UG. After importing the step file and putting it thru Feature Works I'm left with an imported shape and a ton of fillets. If I were to construct this from scratch I would whittle this out using lofted features and a few fillets.
My question, is there a way to reverse engineer lofted features from an imported step file? This part has flowing curvy surfaces with even thickness throughout like sheetmetal. Could I select the filleted feature edges to use as guidlines for a loft?
Prior to downloading their step file I created my own model using an undimensioned print as a visual reference. I used several lofted features and other extrusions and fillets and it came out great. Now that I have their model I need to update mine, or reconstruct a new one to be dimensionally the same as theirs.
thanks,
Tom..
thanks,
Tom..
