I'm curious how some of you address this topic. When doing cantilevered retaining walls without a soil report, the default values in the code are pretty crummy. When specifying backfill material, using the gravel mixes with the lower pressures helps a lot (30 psf/ft) vs the native soil (45-60 psf/ft). I don't see the construction side of these very often, but when excavating to build the wall, I'm assuming they would cut the soil at a steeper angle than the design failure plane, correct? If so, you have this area between the excavation cut plane and the design failure plane that isn't really "backfill", yes?
If I want to use the lower pressure gravels as backfill, do I need to detail a requirement that they excavate at least as far as the failure plane? Or does that happen anyway since the soil wouldn't be stable during construction if they didn't? I've never seen anyone address this, so maybe I'm just inventing things to worry about (wouldn't be the first time!) I'm talking about reasonable height walls (4-10 ft).
