Results listing
slava74
How I can get the COMPLETE SET of the nodal results in Emag3D? The problem is that I used PRNSOL, PRESOL, PRNSL, PRVECT and many other ways to get the results in approx. 120.000 nodes in 3D problem. I've never got more than 18.000 nodes in *.lis files. Thanks.
Did you try putting your results in a parameter (*vget) and writing it to a standard FORTRAN File (*vwrite) ?
Nicolas
I used to have the same problem. After doing the ouput you have to close the file, otherwise only a partial output is done. I don't remember the command, but if you go check the help file for the output command you will see what I mean.
