Been 35+ yrs since taught and haven't used since. Outside my office is a plant loudspeaker. It has two wires powering it. The PA system was changed to where there is a very loud and annoying 1000HZ tone just before the message. I would like to filter out the 1000HZ with a choke coil and a variable capacator. Could someone plug in the values and whether it would be series or parallel. If this idea won't work is there anything I could do to disable this tone locally and not at the main amp?
