I've been working as an engineer for the past 7 years, but mostly on large scale commercial & residential projects.
A friend has asked me to help design a retaining wall for his house.
The concrete design is easy, but normally on projects I have a full geotech report to give soil type, allowable bearing, active pressures, passive perssures, etc. Because this is such a small project, that isn't going to be an option here.
Are there standard/conservative design values to use in cases like this? Do you give a couple designs for the contractor to pick from once he determines if the wall is founded on clay, sand, silt, etc (this feels like it's asking for trouble)? Provide notes with the assumptions and request the contractor notify you if any of the assumptions are off?
Surely a geotech engineer isn't required on every project..
