markreme
- Oct 28, 2006
- 2
Everyone,
I have a friend who is building an addition to his home. The framing contractor did a few thing that the building inspector is questioning. As a structural engineer (I do not have too much experience with residential framing though),I am looking for some additional opinions.
Here are the problems:
1. The contractor staggered the roof rafters 8" o/c, and thus dd not provide collar ties. He also did not cut a few of the rafters at the proper angle to correctly meet the ridge board, and placed shims in the space. The building inspector is concerned over there being no collar ties, and the shims.
2. The inspector is also questioning the stagger in the rafters (says they should be a max of 6.5").
3. In the basement, due to not placing the basement wall in the correct place or something, the contractor notched the ends of all of the floor joists where they meet the sill. The ends of the rafters are notched at a depth of 2.5" and 7" long, with only 4" bearing on the sill. The max span is 16' (the other end of the joists are correct.)Joists are doubled/tripled under bathroom and partition wall.
What does everyone think? I thank everyone in advance for their help.
Mark E. Reme, PE
Mark E. Reme, PE
