yoel280206
- Feb 9, 2010
- 11
Hi all,
Please let me know your opinion.
I know a turbine with design working inlet pressure 150-200 psi and outlet pressure 50 psia.
So the pressure ratio is around 3-4.
The working fluid is R134a.
I want to replace fluid with methanol which has lower working pressure.
The design inlet pressure turbine is 1 bar = 14.5 psi.
And the outlet pressure turbine is 0.27 bar.
The pressure ratio is around 3-4 also.
Because of similar pressure ratio, you think, can i just replace the fluid of R134a with methanol?
Thank so much..
Thank so much..
