abeschneider
Hi, I apologize if this has been discussed before, but I couldn't find anything when I searched.
Is it possible to replace members of:
(1) constraint pairs - ie: if a line is constrained "colinear" with a "datum plane #1", how can I change the constraint to be "colinear" with a different "datum plane #2"?
(1a) dimension - same basic question as above
(2) mates - ie: if "datum plane A" from "part1" is mated to "datum plane B" from "part2", how can I change the mate to a different plane, "datum plane C" in "part2"?
This is very easy to do in CATIA V5 - you can always see the parent/child relationships, and just contextually "replace" the desired parent.
NX4, WinXP-32bit.
other keywords: reparent, replace, mate, constraint, dimension
NX4, WinXP-32bit.
