- Thread starter
- #861
C
CPiotrowski
Guest
You are right to use a skeleton if you plan on having different parts and panels. THis is what I do but its not easy to manage if you area new pro-e user. I made the mustang as one part because I didnt have the time to do it in an assembly considering I was just messing around. I would definetly replace your pictures with blueprints. It is imparative that your three views line up as much as possible and that your able to see main body lines. Here is the print you need:
http://www.the-blueprints.com/modules/bpview/bpview.php?nr=7 91
[url]http://www.the-blueprints.com/modules/bpview/bpview.php?nr=7 90[/url]
Edited by: CPiotrowski
