It's good to be back!
@stevenqneuk
I have downloaded most of my textures, and I use graphic library textures, but then there is also a need to create my own.
Here are few links where you can download some great textures:
http://textures.forrest.cz/
http://astronomy.swin.edu.au/~pbourke/texture/
http://www.mayang.com/textures/
@CPiotrowski
Thanks for compliments and suggestions
@Skint
Thanks for compliments, I'm try my best to use full power of ARX
@Miko
This gearbox, is part of my program to create hand winch, and it was fully calculated; dimensions, module, tooth stress analysis, torque and bending of shafts, bearing pressure, and so on
Gears have full tooth profile, and I used Involute curve.
Yes I used slide bearings because it is for small speeds, and it is easy to lubricate with grease.
Also my other components of construction are calculated (although only in MathCad, I didn't have time to create mechanica analysis, but I attend to create some for hook and maybe one more component).
So with this bachelor project, you are then almost finish your university, thats great news, congratulations!
I have seen your pictures from animation, it seams great, is it possible to upload full animation?
@James
Yes there was a lot modeling time, and a lot time spend in calculations, once you calculate go to Pro/E, model it, then with results go back to calculations, recalculate, back to Pro/E for final results. Real engineering stuff, and If I was supposed to do it manually it would be disaster
Thanks PTC for ProE!
Note: I have noticed, that on my picture of hand winch, there aren't shadows, and winch is to far from wall, I must repair that and post another pic
