Nice renders guys
Red Devil your renders are perfection
Skwasim good work your every render image is better
Now a little bit more info:
If you got photolux under rendering settings then you got ARX module.
Graphic library is only library with materials for rendering usage; that toes not mean that you have ARX module (see above explanation). Although I don't know if graphic library works and with Photorender (Photorender is tool for rendering within basic ProE package).
ADVANCED_PHOLUX_OPTIONS is a
Hidden option that means when you type it in your config options it wouldn't show any suggestions for its value (that what happens to you Skwasim), because it is hidden
Hidden options exist because PTC use them in development of ProE version or for test them for future versions (basically they are working versions, and some of them aren't finished to the end of existing release etc).
Skwasim just type ADVANCED_PHOTOLUX_OPTIONS and for its value type YES press enter and you will have it in your config.pro option.
Skint yeah I know what it was problem to achieve that model is sitting on floor but there is solution for this.
I don't know if you guys reeded this thread that James Lynch started about rendering but I suggest that you read all those post, there are a lot useful tips for rendering as well as great pictures (Skint including tip how easy and fast setup model on floor
[url]http://www.mcadcentral.com/proe/forum/forum_posts.asp?TID=27 756&PN=6&TPN=1[/url]
Oh yes and there are 2 models that James left to all of us to study how model some great products. Just check it out
