Render sets NX 11
venomex
Automotive
IN
Where do I find the render sets option to apply for a view in NX 11?
I can create groups and add parts to it in settings, but when I go into settings of a view and general tab I don't see render sets option like in NX 10
Pratham,
Using NX 11.0.0.33
For the view, Settings, Common -> General -> Render Sets group -> Define in View (see image below).
Anthony Galante
Senior Support Engineer
NX3 to NX11 with almost every MR (24versions)
Strange, I just tried it out in another assembly drawing and it showed the option like you showed.
But in another drawing( for which I posed the query) I don't see it.
Attached image of settings box.
Pratham,
Using NX 11
Is it hidden because it is collapsed (see attached video).
Link
Anthony Galante
Thanks Anthony...That solved it...I had to expand the settings from collapsed....
Again thank you very much...but I wonder why when I created another sample/test drawing to check the render sets option, it was in expanded state but collapsed in the other drawing...
Aren't they supposed to be in the same/ last used settings/state?
Pratham,
Using NX 11
