Mar 23, 2007 #1 Yoman228 Marine/Ocean Joined Mar 5, 2007 Messages 176 If I have use *equation constraint in Step 1 to control node Set with node set B. Is that possible to remove this constaint in step 2, so that I can fix node set A but allowing node set B to move free?
Mar 23, 2007 #2 xerf Mechanical Joined Oct 4, 2004 Messages 674 Location US In general, constraints (e.g., Tie, Equation) cannot be modified from one step to another. One solution might be to use the subroutine MPC. Upvote 0 Downvote
Mar 26, 2007 Thread starter #3 Yoman228 Marine/Ocean Joined Mar 5, 2007 Messages 176 Solved the problem with connector (stiff spring) as they are elements and can be removed in step 2 Upvote 0 Downvote
