llamallama
I am currently overseeing construction of an industrial WWTP. The influent has alot of organic material that we are feeding to an anaerobic digester. The influent passes through chopper pumps prior to entering the digester.
Because this is an industrial plant we sometimes have nuts, bolts, welding rod, cans, etc. in the influent. In our previous system this wasn't a problem, but now there is a fear that we may take out a pump with a metal object. This could essentially shut down production in the facility until the pump was replaced.
We don't want to eliminate solids in the influent because we need the organics. So the removal method would need to be selective. Also the organic solids are mostly peels and vegitable matter that would clog most mechanical removal devices like bar screens.
Does anybody know of methods for removing metal (some non-magnetic) from influent while allowing a high volume of stringy, organic solids through?
I appreciate any ideas.
