Mauriciocol
- Aug 5, 2003
- 8
Hi there
Is there any restriction to remove a smoke detector fom an electrical closet
The closet size is 6'x3'. In front of the closet is a double door which avoid the clearances problems. The contractor is requesting to remove the smoke detector due to the lack of space to install it.
Is there any restriction that you know or a standard that I can refer to to make the contractor install the smoke in place.
Thanks for your help.
