When flipping the arrows on a horizontal dimension to the outside, the leader line remains between the two inverted arrows (on the inside). How can i remove this?
Without seeing what you are looking at.... do you think it's possible that when you "cleaned up thedimensions" on the drawing that you had the "CREATE SNAP LINES" box checked? If that was the case all you'd have to do is click on the Snap Line and hit the Delete Key. I know there must be more to this then what I'm seeing, but I've baffled myself with simpler "problems".
hey iam not getting. do u want to erase the line between the arrows in diameter dimension?
if u change the setup option text orientation to horizontal, the line between the arrows will disappear. and if u want to remove the line between the arrows in diameter dimension, go to modify option and then click dim params. there u will find the diameter dim type. u click that and ur diameter dimension type will change. then flip arrows, u wiil see the line between the arrows disappears.
