Remote vacuum brake servos
jamesgritt
Automotive
May 17, 2007
1
Can anyone tell me the relationship between input fluid presure and displacement vs outlet fluid pressure and displacement in a remote vacuum servo?
As far as I can tell the outlet fluid pressure is the inlet fluid pressure multiplied by the boost ratio (for a set vacuum pressure) but I am unsure of the ratio between the two displacements.
Any help is greatly appreciated
James
Basic hydraulic principles would lead one to believe that if you double one you have to halve the other. double the pressure, halve the volume
