To increase the reliability of electronic components, we are often operated at less than our absolute maximum ratings. Companies often use a 'Derating Policy' that specifies the various components (resistors, capacitors, diodes, transistors, ICs, processors, etc) and specifies which parameters (voltage, current, power, temperature etc) of these components are to be derated (reduced).
We need to know which parameters need to be derated and by how much for all commonly used electronic components. Thank you!
