Relative Humidity wet gas stream HYSYS
nlkw
Chemical
Feb 6, 2008
7
Hi, how do I get the relative humidity for a wet gas stream using Hysys?
I presume you mean the relative humidity defined as the ratio of the partial pressure of water vapor in the mixture to that of saturated vapor pressure of water at a prescribed temperature, knowing operating temperature and water saturation pressure and water content/fugacity in the mixture (I use tools as Prode and REFPROP for these calc's) it is easy to get the results in Excel, I don't know your simulator but if there are no direct methods you can follow the same procedure...
Try getting/installing the extention "gasprops" - i believe you can download it from the suppport page. It will tell you this.
Maybe its already bundled today - im not sure.
Best regards
Morten
