GalileoG
- Feb 17, 2007
- 467
I have an existing steel column with 8ft deep trusses that frame into it on each of its 4 sides. These trusses will transfer new load to the column and so the column will need to be reinforced. I am looking at welding plates to the column to form a boxed section. The reinforcing plates will extend to just 4in below the truss bottom chord.
How would I go about analyzing the capacity of this new reinforced column? As the reinforcing does not extend the full height of the column (to the truss top chord where the load is imparted) is the reinforcing even effective given that there is a weak link, the top 8ft?
So if the reinforced column is 30ft tall and the unreinforced section is 8ft tall above it, should each segment be designed for the full unbraced length of 38ft or their respective lengths only (30ft and 8ft)?
My understanding is that it is the former, and so the column reinforcing as suggested is not effective at all. Intuitively, I feel that is not the case, but I can not rationalize it.
Any suggestions?
Any suggestions?
