Reinforcement for Large Concrete Columns
x5bulldog
27
Can anyone point me in the direction for reinforcing large concrete columms. I want to see typical longitudinal reinforcement arrangement for columns on the size of 10ftx10ft. Is it required to add additional steel away from the perimeter? Also when adding lateral support to some of the longitudinal bars, how are the ties usually arranged? Thanks
Attached is a copy of a portion of the concrete masts used at the Alamodome in San Antonio, Texas.
This was a 15 ft. wide octagonal column with a hollow inside area (rotated octagon).
Just an example of a large concrete column reinforcement. Not sure if this provides you with anything relevant to you situation.
 http://files.engineering.com/getfile.aspx?folder=0b3610a6-a233-4959-8773-450edd586455&file=Alamodome056.jpg
Thanks again for all the help!
I found what I was looking for. I switched to bridges(even though I am not designing a bridge) and began looking at reinforcement layout for Single-Column Piers since a lot of them are made-up of large dimensions.
