iquk
- May 30, 2017
- 4
Dear All,
I am looking for a software which can design Base plate with Anchor bolts. I am Working in space frame so here we have to support some ball joint or mediator (half Solid sphere) on base plate. Most of the software are having I section or box section as columns on base plate. Is there is any software for base plate and anchor bolt design in which I can use any structural section like I section, Solid Circular, pipe , tube etc any shape as column? It should considered Bi axial moment also. And some time I have to use different shape of base plate like L-shape, C shape with through bolts passing through slab or beam. For reference I had Attached some images also. Please advice if anybody knows software to analyze and design such base plates.
