I have a (hopefully) simple question about the central air system in my condo. When I run it for a long time the refrigerant line supplying the heat exchanger freezes up. I suspect that this might be normal for days when it is a bit humid. I have the vent in the basement taped off so all of the cold air heads up into the house. I checked the condensate pan and drain, seems ok. The compressor, fan and everything outside the house seems ok too.
So my question is why is the line freezing? Should I insulate the indoor line? I'm not sure if the whole line is uninsulated or just the short section near the handler. I'll check later. Should I unblock the basement vent to let the air in the basement cool (and dehumidify)? Is is possible that the heat exchanger in the air handler is clogging up and not flowing properly? The unit is very old, 1983 Carrier with a Payne horizontal air handler.
Any help is appreciated. Thanks.
