Say I have a drafting of an assembly (or part) with several views.
I change the position of the assembly and I want that only one view reflects the new position (and the other stay not uptaded).
How can I do it?
When you say "change the position of the assembly" are we talking about moving one or more Components in an assembly to show an alternative position, like moving a handle or opening an inspection panel? If so, save the alternative Component positions as Arrangements in your Assembly and then when you create your Drawing, after adding all the views that shows the Assembly in it's 'normal' position, then add an additional view only this time use the other Arrangement, like I did here with a Drawing where normally it shows the valve 'Closed' (the default Arrangment) but where I added one additional view showing the valve 'Open' using a different Arrangement:
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA Siemens PLM: UG/NX Museum:
