Hi All,
Could you assist me to know 1) correct syntax of refile_part utility and executing procedures? 2)refile overview. Thanks in advance
trying go through below mentioned options. But not successeded..
usage: refile_part [options]
where the [options] are:
[<filename>] Refiles file <filename>.
[-c] Creates components if necessary during upgrade.
[-co] Compresses the part(s) when refiling.
[-d] Convert all parts/UDFs in current directory.
[-d <dirname>] Convert all parts/UDFs in directory <dirname>.
[-g] Upgrade components.
[-l] Logs a short report to the syslog.
[-l <filename>] Logs a short report to the syslog and <filename>
[-ll] Logs an extended report to the syslog.
[-ll <filename>] Logs an extended report to the syslog
and <filename>.
[-o <filename>] Sets new file <filename> as the destination.
[-o <dirname>] Sets existing directory <dirname> as
the destination.
[-convert_mcs <filename>] Converts mating conditions to assembly
constraints. Logs a constraint conversion
report to <filename>.
[-mc_parts_only] Used in conjunction with convert_mcs
to specify only refile parts which
contain mating conditions.
[-mc_dry_run] Used in conjunction with convert_mcs
and <filename>.
the destination.
