NX open utility help
Ram K
IN
Hi
I want to get assembly structure (Partnumbers) of without opening the part in NX. Can somebody suggest NX open utility or API
Thank you Cowski. I am able to run utility ugpc -s to get the structure in Native NX, Could you please advise on how to run the NX Utilities in Teamcenter environment?
Any kind of help is greatly appreciated.
I don't think that ugpc works in a TC environment because the assembly structure depends, in part, on your revision rule(s). I suspect that you will need to use an ITK function (or write your own) to query TC if you want to do this programmatically. You can do it manually in TC by sending the item to the structure manager - doing so will not open the part in NX, but will show you the structure based on your given revision rule.
www.nxjournaling.com
